Home » Sponsored » Pi Speakers » My first kit, any words of wisdom would be appreciated
My first kit, any words of wisdom would be appreciated [message #40133] Tue, 04 February 2003 05:51 Go to next message
bsuhy is currently offline  bsuhy
I am embarking on building my first ever kit, the 2-Pi Bass Reflex speaker. Does anyone have any words of wisdom, gotchas, etc., before I start? Any comments or helpful suggestions would be appreciated.
Thanks,
Brian
Re: My first kit, any words of wisdom would be appreciated [message #40134 is a reply to message #40133] Tue, 04 February 2003 06:00 Go to previous messageGo to next message
ozzi is currently offline  ozzi
build the towers if you have the space.
Re: My first kit, any words of wisdom would be appreciated [message #40135 is a reply to message #40134] Tue, 04 February 2003 06:19 Go to previous messageGo to next message
Is that just the case of building the tower enclosure? I assume they are the same drivers, but you have the option of building either enclosure, right?
Thanks,
Brian
Re: Check archives [message #40136 is a reply to message #40133] Tue, 04 February 2003 07:00 Go to previous messageGo to next message
there's lots of good tips in the archives- some time spent browsing them would pay off. Till E. and bmar, among many others, have posted a lot of advice that would be very helpful, especially on the woodworking side- that goes way beyond the "measure twice and cut once" adage. Plan everything well and work methodically and you'll do fine.
Measure twice cut once and just take your time nt. [message #40139 is a reply to message #40133] Tue, 04 February 2003 08:40 Go to previous messageGo to next message
Robert Hamel is currently offline  Robert Hamel
nt.
"A Wet Bird Never Flies At Night" [message #40141 is a reply to message #40133] Tue, 04 February 2003 09:44 Go to previous messageGo to next message
All the wisdom I have.
Just post questions as you go and before the glue dries!
Have fun!
Re: My first kit, any words of wisdom would be appreciated [message #40143 is a reply to message #40135] Tue, 04 February 2003 11:24 Go to previous messageGo to next message
The two π and two π tower speakers use the same components, so you can build either cabinet. I'll send plans for the tower two π speakers so check your E-Mail.
Re: My first kit, any words of wisdom would be appreciated [message #40144 is a reply to message #40143] Tue, 04 February 2003 12:03 Go to previous messageGo to next message
Wayne,
Space really isn't the issue, so maybe the towers are the way to go.
Is there a radical difference between the two speakers in terms of sound? I have read that the tower has more base, but maybe its looser? I was going to put the others on stands anyway, so I guess I might as well build the tower.
Which brings me to material. MDF will be heavier than particle board, but isn't it stiffer, and stiffer is better, right? I am thinking the sound characteristics will probably be unnoticable to my untrained ear, but I guess I should start with the "right" material.
Thanks,
Brian
You've got mail! [message #40147 is a reply to message #40144] Tue, 04 February 2003 15:11 Go to previous messageGo to next message
Both speakers sound nice, but the tower two π goes about an octave lower.
Re: "A Wet Bird Never Flies At Night" [message #40148 is a reply to message #40141] Tue, 04 February 2003 16:45 Go to previous messageGo to previous message
Previous Topic: Plywood vs. MDF
Next Topic: π three-way passive crossover 250Hz/1.6kHz
Current Time: Fri Nov 13 07:18:42 CST 2026
