Home » Sponsored » Pi Speakers » Tweeter 1/2" to low :(
Re: OR...... [message #40076 is a reply to message #40075] Tue, 28 January 2003 18:28 Go to previous messageGo to previous message
....you could take the cut-out you made when you drilled/routed the hole, or make a new one out of the same material, and epoxy it into the hole with 'slow-set epoxy for wood'.
Wait 24 hours and drill/rout the hole all over again. Cut discs of felt to surround both tweeters which they could use anyway, and the whole affair is your little secret.
My fixes are better than Bmars because I have much more practice fixing mistakes:)
Previous Topic: Theater 4pi audition
Next Topic: Pi Theater 4s at Outdoor Wedding Reception
Current Time: Wed Nov 04 07:13:02 CST 2026
