Home » Sponsored » Pi Speakers » Wayne, please review piezo attenuation values
Re: Wayne, please review piezo attenuation values [message #39957 is a reply to message #39956] Sun, 19 January 2003 20:08 Go to previous messageGo to previous message
I don't know if this will do as much of an explanation, but... If you perceive a capacitor as a resistor with a frequency dependent resistance (resistance falling with frequency going up) the higher values of capacitors have the LOWEST resistance, & the lower values the highest. So that explains why the low value resistor have the highest damping (in Wayne's table) - & the fact that a piece of wire, which in this case can be compared to a capacitor with an INFINITELY high value, don't dampen at all. Hope I helped you a little here :)
Previous Topic: Going to build the 800a009dB X-over from scratch; need help with C5 and R3
Next Topic: What amp do you prefere with your Pi One, or Two's?
Current Time: Mon Nov 02 04:23:50 CST 2026
