Home » Sponsored » Pi Speakers » 16 ohm md2001
16 ohm md2001 [message #39908] Wed, 15 January 2003 14:54 Go to next message
djstan is currently offline  djstan
Hoping soon to build the pi4's with the omega 15 woofer, but realized my eminence md2001 drivers are 16 ohm units. Whats values do i use for a 1.6 khz crossover. I'm assuming the capacitor values would halve and the coil would double in the high-pass components. Right or wrong? But what about the compensation and L-pad values?
Great site, keep up the good work.
Re: 16 ohm md2001 [message #39909 is a reply to message #39908] Wed, 15 January 2003 20:08 Go to previous message
I suggest using Spice to find values for R1, R2 and C1 that are appropriate for a 16 ohm MD2001. You can model the MD2001-16 tweeter using the PSD2002-8 model included in the distribution file, but substitute 12 ohms for resistor R4, which represents voice coil resistance (Re). Inductor L4 is voice coil inductance (Le) and it should be changed to 0.2mH. Now all you have to do is model the circuit, finding values for R1, R2 and C1 that give the response like what is shown below.
Previous Topic: Active filters
Next Topic: JBL D130/075/N2400 Combo
Current Time: Sun Nov 01 19:15:22 CST 2026
