Home » Sponsored » Pi Speakers » Let's try those 2Pi Towere pictures again.
Re: Dimensions: Narrower front baffle [message #39884 is a reply to message #39882] Tue, 14 January 2003 06:23 Go to previous messageGo to next message
wasteh202 is currently offline  wasteh202
Oscar, I would like to be able to help you very much here but I don't know that I can help you much (as far as a comparison). This pair of 2Pi Towers is the only Pi design that I have ever heard. I think as long as you keep the overall cubic inch s box size to the design that you will not deviate from the desing tuning. My box and port happen to be a bit bigger that the design size. Wayne says that changing the dimensions is not a problem, just keep the size the same. I change the width and depth sizes to better accomadate my sons bedroom.
I can tell you that they sound great. I was listening to some Magnepan MMG (another great value in speakers, just not very sensitive or dynamic) speakers about a year ago. When my wife and daughter broght home two little kittens I packed and put away the MMG's (great cat scratching posts). I replaced them with some small monitors on the bookshelf (I refer to this day as "the day the music died). Well, since building the 2Pi Towers for my son I cannot enjoy listening without the Towers and find myself sneaking in his room while he is at school to listen to my music.
Re: Dimensions: Narrower front baffle [message #39902 is a reply to message #39884] Wed, 15 January 2003 02:47 Go to previous message
ozzi is currently offline  ozzi
Could you please email me your sizes, I would like to compare.
Thanks for the info, it helped a lot in making the decision.
Oscar
Previous Topic: Woofer-tweeter
Next Topic: Active filters
Current Time: Fri Nov 06 06:30:20 CST 2026
