Home » Sponsored » Pi Speakers » 2 pi towers - wiring question
2 pi towers - wiring question [message #39732] Sun, 05 January 2003 13:22 Go to next message
jeff g is currently offline  jeff g
i've just finished the cabinets for the 2 pi towers and had a question about the wiring - is it ok to attach the wire to the back wall of the cabinet or should i just let it hang down the middle?
also, does anybody have experience with spikes on the bottom of these speakers?
Re: 2 pi towers - wiring question [message #39734 is a reply to message #39732] Sun, 05 January 2003 14:23 Go to previous messageGo to next message
wasteh202 is currently offline  wasteh202
Good question...I was wondering about some spikes or at least feet for the towers to seperate them from the floor, but since my sons room is carpeted and he is moving them around a bit as they are still new, I have not gone there.
Anybody?
Oh by the way I finished the second tower yesterday. I still need to put the finish on it though.
Re: 2 pi towers - wiring question [message #39742 is a reply to message #39732] Sun, 05 January 2003 16:31 Go to previous messageGo to next message
There should be nothing wrong with attaching the wire to the back wall, as long as you make sure there's still enough 'free' wire hanging from behind the driver(s) so you can get them out of the box if you need to. You may wan't to gain access to the interior of the box in the future to experiment with damping, change drivers, whatever. Also remember to do the same at the terminal end(!)
Strain reliefs [message #39744 is a reply to message #39732] Sun, 05 January 2003 17:30 Go to previous messageGo to next message
It's a great idea to use nylon strain reliefs to hold wires in place when building two π towers and other large speakers. Having wires hanging is no real problem, but the strain reliefs keep them from pulling loose or vibrating against something when the speaker is in use.
You can get a package of these strain reliefs at most hardware stores. I think Radio Shack stocks them too.
spikes and carpet [message #39752 is a reply to message #39734] Mon, 06 January 2003 07:12 Go to previous messageGo to next message
are a pain in the rear! Slight relocations required LIFTING the spikes free of the fibers...after a few weeks I turned the spikes inward. Sam
BTW, do you REALLY want his speakers coupled to the floor better? better bass for him, AND the family member in the next room :(
Re: spikes and carpet [message #39758 is a reply to message #39752] Mon, 06 January 2003 09:06 Go to previous message
Yeah, well I guess no never no until you try... right?
Previous Topic: Cornerhorn away from corner
Next Topic: New Participant
Current Time: Sat Nov 07 04:04:47 CST 2026
