Home » Sponsored » Pi Speakers » Need a small, practical, 101dB 2-way?
Need a small, practical, 101dB 2-way? [message #39723] Sat, 04 January 2003 16:24 Go to next message
The latest and greatest "Project" speaker from JBL, ...K2.
With the 811b horns I stole from Speakerman and another pair of 2226j's, I think I might get this nuts.
What the heck, you build'm one board at a time.
Hey Wayne, it's just a pair of Pro4's stacked with a horn in the middle, right? No Hay Problema. 250 lbs each. I might need a little help getting'em into the Bumstead, or whatever that hotel in Lima is called.
Re: Need a small, practical, 101dB 2-way? [message #39724 is a reply to message #39723] Sat, 04 January 2003 18:33 Go to previous messageGo to next message
spkrman57
TillE,
I am not sure about the 101db sensitivity on this one, check out the foam surrounds. read the posts concerning dual 15" formats and cancellation on the JBL 4648's at around 817hz, I believe SamPayne Jr went over this subject previously.
Ron
Re: Need a small, practical, 101dB 2-way? [message #39729 is a reply to message #39723] Sun, 05 January 2003 07:51 Go to previous message
A pair of 2235H's would get you closer to the design than the 2226J's, at least if you want to get all the way down that is. I think these babies are around $12,000.00 a piece (not pair).
Kelly
Previous Topic: Port variation for doubled woofer
Next Topic: Thermionic Pi 7 Cornerhorns
Current Time: Thu Nov 05 20:43:41 CST 2026
