Home » Sponsored » Pi Speakers » Port variation for doubled woofer
Port variation for doubled woofer [message #39707] Fri, 03 January 2003 17:08 Go to next message
DRC is currently offline  DRC
If I want to use two of a given woofer in a single cabinet, I need to double the cabinet volume, correct? But how do I know how (or if?) to vary the port size?
Getting in deeper and deeper . . .
Keep your ears and your mind open.
Re: Port variation for doubled woofer [message #39710 is a reply to message #39707] Fri, 03 January 2003 23:59 Go to previous message
To put two of the same woofer in a cabinet, you can basically double the volume and tune the port to the appropriate frequency using Helmholtz formula. You will find that PiAlign is able to do this for you by simply entering a value of "2" in qty instead of "1."
Previous Topic: 1 pi question
Next Topic: Need a small, practical, 101dB 2-way?
Current Time: Sat Nov 14 15:02:15 CST 2026
