Home » Sponsored » Pi Speakers » 4Pi Professional Series
4Pi Professional Series [message #39578] Mon, 23 December 2002 13:50 Go to next message
pp-45 is currently offline  pp-45
Just wondering if the 4Pi professional series with JBL drivers would really be 100db efficient.
I thought JBL 2226 woofer is only 97db and the overall sensitivity will be that of the least efficient part of the system.
4Pi's [message #39579 is a reply to message #39578] Mon, 23 December 2002 14:14 Go to previous messageGo to next message
I'm going to go out on a limb here and say that the sensitivity is likely a moot point in your case at least with this particular driver combo. I say that judging from your nic that you will be running a 45 watt push pull tube amp. My experience with 4 Pi's is that the more power on tap the better they sound. Not that they sound bad with small amps, a 2 watt SET amp sounded great in the mid range and top end when we demoed it, but the bottom end was very lacking. I normally run my 4Pi's with a 75 watt crown SS amp. It sounds great, good bass, very detailed but nothing like the 300 watt Luxman that I've started using again....it literally will beat you up if you want it to, the 2226H really seems to need some power to get the best out of it, at least in my experience so far.
Kelly
(Actually , the set amp midrange and top-end was incredible, clear, detailed and yet it took the edge off so so recording with out loosing anything....makes ya kinda think....shhhhh don't say it Wayne will kick me off....)
Re: 4Pi Professional Series [message #39581 is a reply to message #39578] Mon, 23 December 2002 15:11 Go to previous messageGo to next message
There are two versions of this model, one having a 2226 and the other having a 2227. The model containing a 2226 is rated at 97dB and the one containing a 2227 is rated at 100dB.
4-pi pro and SET's again [message #39583 is a reply to message #39579] Mon, 23 December 2002 18:11 Go to previous messageGo to next message
spkrman57
Hi all,
Do I hear that wonderful combination of SET's and JBL 2226's again, They may not hit extreme SPL's, but sound damn good to where you don't miss what they don't do, just got to love what they do when they perform like those of us who do know have experienced!
Regards, Ron
Re: 4Pi Professional Series [message #39584 is a reply to message #39581] Mon, 23 December 2002 20:39 Go to previous messageGo to next message
Thanks - I am thinking about the 4Pi and just want to make sure that they are 100db. Sounds like I will have to use the JBL 2227 woofers.
Re: 4Pi Professional Series [message #39586 is a reply to message #39578] Tue, 24 December 2002 03:35 Go to previous messageGo to next message
So what type of amp are you going to drive the 4 Pi's with?
Kelly
Re: 4Pi Professional Series [message #39588 is a reply to message #39586] Tue, 24 December 2002 04:12 Go to previous message
Kelly,
I have quite a few amps: a single ended 45, a single ended 10 - these two I use the most. In the closet are: a single ended 300b, a Pilot 232, a Scott 222C, an Eico HF-86. I am thinking about 4Pi with the JBL 2227. I think every 3db count when it come to single ended.
Previous Topic: Studio series Two Pi Towers
Next Topic: Question for Wayne or others: bi-amping with stock Eminence crossover?
Current Time: Sun Nov 22 20:25:23 CST 2026
