Home » Sponsored » Pi Speakers » Pictures of the "corner horn"
Re: Wow! Very interesting! [message #39492 is a reply to message #39454] Mon, 16 December 2002 08:07 Go to previous messageGo to previous message
Walt is currently offline  Walt
The volume of the rear chamber should change if another compression ratio is used. In fact this volume varies lineair with this ratio.
For some horns it really makes a difference if the volume is chosen wrong. Might cause 5-6dB bumps! Use McBean to model a rearloaded hyberbolic horn with:
l=2.8m
ah=75cm2
am=850cm2
In this case the volume should be kept as small as possible!
Best regards,
Walt
Previous Topic: 2pi's
Next Topic: Pi-aligned line array?
Current Time: Thu Oct 29 05:21:40 CDT 2026
