Home » Sponsored » Pi Speakers » High output compression drivers
don't discount rebuilt altec 900's [message #39482 is a reply to message #39469] Sat, 14 December 2002 16:07 Go to previous messageGo to previous message
I was ordering some altec 909 'phrams from Bill at Great Plains, and he said they have tested flat, on axis, mounted on 511's, out to 20kHz. Probably would do the same on jbl 2370 flares, which also compensate for the falling CD response by narrowing the vertical dispersion as frequency increases. A "rebuilt" pair with new innards will run maybe $350-400/pair, and handle something like 75 watts, about 112dB/watt eff. Less $$$ than NEW jbl's. 2 bolt mounting only, I'll be trying a pair in my quasi-4 Pi Pro's on the H-290 horns soon. Sam
ps, beat up 908's with blown coils are CHEAP, new 909 'phrams will cost ~$160/pair, and they are easy to change, then the drivers are "good as new":)
Previous Topic: Plans for 2 Pi Tower
Next Topic: corner horns
Current Time: Sat Oct 17 16:33:12 CDT 2026
