Home » Sponsored » Pi Speakers » Seven PI Corner horn and Altec 515's
Re: Seven PI Corner horn and Altec 515's [message #39367 is a reply to message #39366] Fri, 06 December 2002 01:14 Go to previous messageGo to previous message
You will find the seven π cornerhorns are an excellent, high-performance system with your Altec components. There are many others here that have built π speakers using Altec woofers and compression drivers and reported great things about their systems.
The trouble is that all the plans are drawn for current production devices, specifically, those made by Eminence and JBL. As such, the cabinet would not be optimal for your woofer. I would recommend that you enter the woofer's parameters into PiAlign and let it calculate cabinet dimensions for you. If memory serves, the Theater Series seven π and Professional Series seven π-18 speakers are closest to what you'll want in size, and the crossover used in the Professional Series seven π-18 model is the one you'll want.
I'd be happy to send the plans for either of these speakers to use as a starting point, but I think it would be best to do a little studying first. Download the PiAlign program and read the "readme.txt" file contained in the distribution archive. It is only a couple of pages long, so it won't take long to read and will familiarize you with how to run the program and what parameters are required. You'll use familiar T/S specs, with one exception, Qd = 1/Qts. Other parameters Vas = Vad and Vas = Vad, but all this is described in the "readme.txt" file, so I simply encourage you to read it and run the program. If you have any trouble, feel free to ask.
Previous Topic: Theater 4's w/ EL-84 at 14 Watts per
Next Topic: cabinet makers, please help
Current Time: Wed Oct 21 01:45:28 CDT 2026
