Home » Sponsored » Pi Speakers » JBL 4648A with SET's?
yes, [message #39362 is a reply to message #39359] Thu, 05 December 2002 13:13 Go to previous message
each "nominal 8 ohm z" 4648a-8 contained a pair of 2226J's. I tested two separate systems, from the amp ends of the speaker wire. BTW, a pair of 16 ohm resistors in PARALLEL will measure 8 ohms, so these measurements are pretty normal.
For all intents and purposes, the amp is "seeing" the same load as a single 2226H when it's driving a 4648a-8 system containing a pair of 2226J's. The MAIN reason I'm running the dual 2226J's is ECONOMIC. But it still takes the pair of them per side to do the work of a single 2035H or 2226H. There is no inherant "benefit" running dual 16 ohm drivers vs. a single 8 ohm one in this specific case. UNLESS 1200 watt power handling capability is needed:)
Dual woofer DOWNSIDE is the larger enclosure needed, the extra weight involved, the "notch" at 820Hz.
I'm not sure about what a SET will do with the back emf...burp it back into the HF driver like a chirping piezo?:(
Dual woofer UPSIDE...hmmm...looks cool? Positions the HF horn at a GREAT height relative to the listener. Oh yeah, and the "power response" matches that of a 90x40 horn at 800Hz. Whatever that means:) Sam
Previous Topic: 1 PIs in 9ltr sealed box ??
Next Topic: pi 7 and suitable driver,and wayne,dont u get tired of this lol
Current Time: Wed Oct 21 07:25:30 CDT 2026
