Home » Sponsored » Pi Speakers » Impeadance of Pi speakers using 1.6khz crossover
Re: as measured my quasi-4 Pi hf z [message #39307 is a reply to message #39306] Sun, 01 December 2002 13:36 Go to previous message
Some of 'em aren't quite as high as 20 ohms. The 8dB and 10dB versions, for example, present a slightly lower impedance than the 12dB and 14dB versions. And really, even the 14dB unit only presents about 15-17 ohms at its maximum, depending on the driver used. There's a smaller shunt value and higher series value in the 8dB and 10dB assemblies, so their load is even a little closer to the 8-10 ohm range. But I still like to point out that impedance is slightly higher than some might expect due to the compensation circuit.
I can't recall which cable assemblies you're running, or if yours are different. But the load impedance is pretty easy to find, it's a simple circuit.
Previous Topic: 2Pi -3dB points revisited...
Next Topic: FS/FT JBL Professional Series Woofers
Current Time: Mon Nov 23 12:24:59 CST 2026
