Home » Sponsored » Pi Speakers » 2Pi -3dB points revisited...
2Pi -3dB points revisited... [message #39303] Sun, 01 December 2002 10:08 Go to next message
Hi Wayne! In a previous answer you told me that the -3dB points of the 2Pi Standard & 2Pi Tower are 60Hz & 35Hz, respectively. You also said that the correct tuning frequency for a great variety of box volumes when using the Alpha 10's was 40Hz. Would it be safe to assume that the cut-off point in a box of ~2.4 cu.ft. would be around 50Hz? Thx in advance.
Re: 2Pi -3dB points revisited... [message #39305 is a reply to message #39303] Sun, 01 December 2002 10:50 Go to previous message
Yes, 2.5-3ft3 will get you to 50Hz.
Previous Topic: Isobaric
Next Topic: Impeadance of Pi speakers using 1.6khz crossover
Current Time: Fri Oct 16 22:51:40 CDT 2026
