Home » Sponsored » Pi Speakers » Woofer/Amplifier questions
Woofer/Amplifier questions [message #39269] Fri, 29 November 2002 00:12 Go to previous message
Anonymous
Take two different amplifiers;
Amplifier #1
100w into 8 ohms
200w into 4 ohms
400w into 2 ohms
Amplfiier #2
100w into 8 ohms
100w into 4 ohms
100w into 2 ohms
Amplifier #1 is a conventional design where power doubles
as impedance halves.
Amplifier #2 is a breed that monitors load and lowers the rail
voltages to maintain the same power regardless of load.
Two questions.
1. If amplifier #2 has variable rail voltages, would clipping
occur sooner at 2 ohms vs. 8 ohms load? Suppose rails are +40v/-40V
at 8 ohms, and +20v/-20v at 2 ohms. I argue that you would
clip easier on transients at 2 ohms vs. 8 ohm, others say
100w = 100w, makes no difference.
2. Woofers have an impedance curve that varies with frequency.
Hypothetical -> if an 8 ohm woofer's impedance is 2 ohms
at 60hz, does amplifier #1 output 400w @60hz whereas amplifier #2
only outputs 100w across all frequencies, in which case, people
may interpret amplifier #1 as driving woofers better due to
more power ?
Previous Topic: wiring plan
Next Topic: Spice models for tubes
Current Time: Thu Nov 19 13:08:05 CST 2026
