Home » Sponsored » Pi Speakers » Top octave augmentation?
Top octave augmentation? [message #39182] Sat, 23 November 2002 05:21 Go to next message
Has anyone succesfully added a super tweeter(s) to their Pi's? I have my Theater 4's in a fairly damped room and would like a bit more high freq. Sparkle. I've read in the archives of Wayne's suggesting parallel KSN-1038's, two per channel.
Thanks!
Garland
Re: Top octave augmentation? [message #39186 is a reply to message #39182] Sat, 23 November 2002 11:56 Go to previous messageGo to next message
You might consider using the JBL 2405.
The only problem is once you do this, it is no longer a uniform directivity speaker. You'll be able to hear a change as you move around the room, as the super-tweeter and horn tweeter interact differently at different angles. It might be a fun experiment for you. Try the speaker without a super-tweeter and walk around the room. See how it has the same spectral balance. Now conect the super-tweeter and listen. You'll hear the sparkle change as you move about.
Re: Top octave augmentation? [message #39188 is a reply to message #39182] Sat, 23 November 2002 12:30 Go to previous messageGo to next message
You could try an Eminence APT 50. its a small compression driver that is cheap and you can get it already attached to 3 different little horns. check them out at parts express if your inclined. Waynes suggestion about the JBL 2405 would be the ultimate.
Bill
Question for Wayne [message #39194 is a reply to message #39186] Sun, 24 November 2002 05:51 Go to previous messageGo to next message
Wayne,
How would one add the JBL 2405 to the Theater 4's crossover? I'm afraid I need a bit of hand-holding on this. Is there anyway you could draw up a schematic? I recall a while back you spec'ed out a crossover for the Motorola 1038 with a pair o' resistors and pair o' caps. Would this be similar? and if I were to only want the super high freqs, say above 17or 18K could only a high pass filter be used on the 2405? If so what would an appropriate filter be?
Thanks!
Garland
2405 as top octave device. [message #39199 is a reply to message #39194] Sun, 24 November 2002 13:23 Go to previous message
Here's a crossover that will work nicely for you. Just replace the compression horn cable assembly and add the 2405 circuit.
Previous Topic: 2 Pi Pic
Next Topic: so I wanna build the Pi 2
Current Time: Wed Oct 21 10:48:23 CDT 2026
