Home » Sponsored » Pi Speakers » Gettin' down to Crossover Cases
Gettin' down to Crossover Cases [message #38886] Wed, 30 October 2002 13:37 Go to previous message
DRC is currently offline  DRC
Wayne, your 1602's just got here. They are something else!
Being just a tad impetuous, I'm using them crossoverless with a 1in dome coming in around 2k, "borrowed" from a system that's 94dB/w/m. In doing further reading, I see that folks (Dr. Edgar & others) view the 1602 as more like 94-95.5dB efficient for the range it's likely to be used in, so it's not a bad match just to get "a taste."
Can anyone tell me what I should be doing for the 3-way crossover using the 1602 x-ing over to JBL 2123 @ 300, x-ing over to the Eminence in a Martinelli horn at 3k? Since it's a 3 way using points higher and lower than usual, two drivers not spec'd in the std Pi docs, and the third in a different horn flare, I have no idea what parts of the standard Pi xover docs might or might not apply.
In other words: Duh! Help!
Thanks.
Keep your ears and your mind open.
Previous Topic: Height for the Pi 4
Next Topic: size, shipping, and pricing
Current Time: Thu Nov 19 16:49:34 CST 2026
