Home » Sponsored » Pi Speakers » kilomax 15 in theater 4pi box
Re: thanks wayne! one more question.... [message #38798 is a reply to message #38789] Wed, 23 October 2002 12:07 Go to previous messageGo to previous message
Hey George, try this:
Cut a 5 3/4" round of a matching or same wood then cut a 5" hole in it. Round over both edges.
Cut out the 5" hole in the speaker and trim it out with the ring you made.
Does that increase the length of the port by the thickness of the trim ring? Probably yes but perhaps the round over helps. In any case you could use 1/2 or even 1/4" stock for the ring.
Previous Topic: Pi4 and billies
Next Topic: combination stands and subs for 1 pi?
Current Time: Thu Nov 19 07:27:51 CST 2026
