Home » Sponsored » Pi Speakers » A Question About Reflex Ports
Re: A Question About Reflex Ports [message #38723 is a reply to message #38706] Fri, 18 October 2002 18:33 Go to previous message
In his book "High Performance Loudspeakers" Martin Colloms have a few things to say on the subject. He claims that to make sure to avoid windy noises the port diameter should be 7 cm. (2.8") or more. He also says that the diameter to length ratio should be no more than 1:2.
While the above is easily achieved in larger boxes tuned at frequencies > 40Hz, the opposite is the case when it comes to the now fashionable compact subwoofers with internal volumes well below 40 liters ( < 1½ cu.ft. ), & low tuning frequencies. In those cases a passive radiator is often used or alternatively the ends of a small diameter port are 'radiused' to avoid wind noises.
Previous Topic: Over the Falls!
Next Topic: updated pics on site (crossovers too)
Current Time: Thu Nov 19 10:30:57 CST 2026
