Home » Sponsored » Pi Speakers » sound damping materials
sound damping materials [message #38660] Mon, 14 October 2002 09:43 Go to next message
Anonymous
Your thoughts on this material (see link) sonex
pyramid vs. generic egg crate foam.
Sonex pyramid
http://www.markertek.com/MTStore/product.CFM?BaseItem=PYR-2
standard foam
http://www.foamorder.com/products.cgi?cart=i3X0q0n822M622M53M66n4B1b0Y&item=acoustic
configuration;
* Lambda TD15 woofer
* 5ft^3 rear ported box tuned to 35hz
* 1.5" thick MDF cabinet all around.
* crossover - low pass 800hz - hehe
* 500w feeding the woofer.
Should I increasing cabinet thickness
to 2.25" instead ? hehe
I'm the uber-overkill type of person
so feel free to post esoteric sound
damping ideas - lol
Re: concrete [message #38662 is a reply to message #38660] Mon, 14 October 2002 13:26 Go to previous messageGo to next message
the uber-overkill would be to cast a box with 6" wall from concrete.
it would be pretty dead
Re: sound damping materials [message #38663 is a reply to message #38660] Mon, 14 October 2002 13:38 Go to previous message
seriously though,
You can get barium loaded vinyl in sheets which is a sound deadening material. it's used in sound proof rooms. idealy you would make a sandwich with MDF|vinyl|5/8 drywal or mason board|vynyl|MDF
other alternatives could be linolium, modified asphalt roofing materials, sand, lead sheet, liquid filled core. The entire box should not be one box. the layers can not be bonded together. you would in a sense have a box inside a box, inside a box. a lot of unequal and random bracing would help too.
good luck
Previous Topic: My new speakers (1 Pi inspired)
Next Topic: Gauss speakers
Current Time: Sun Nov 01 19:58:47 CST 2026
