Home » Sponsored » Pi Speakers » Four Pi Pro Polarity
Handy reference documents [message #38623 is a reply to message #38622] Thu, 10 October 2002 21:52 Go to previous messageGo to previous message
That's right.
JBL used a standard for many years that provided for positive pressure when a positive voltage was applied to the black terminal, which most consider to be the negative post. But since both the 2426 and the 2226 are this way, all components in the system will be phased as expected, when red is connected to red.
But if you're connecting other systems at the same time, this is important to know. There's a handy chart of JBL speakers and conection methods that is included in Professional Series π Speaker kits, and you'll also find it online in the "JBL Polarity Notice" document. Other useful documents that are included in the kits but not sent with E-Mailed plans are the "General Tips" and the "Crossover Connection Tips" documents. These are all small files, so downloads are quick.
Previous Topic: where is the bass for my Beta 12 LTA
Next Topic: Studio Two Plans
Current Time: Tue Oct 06 20:12:35 CDT 2026
