Home » Sponsored » Pi Speakers » Four Pi Pro Polarity
Four Pi Pro Polarity [message #38618] Thu, 10 October 2002 17:24 Go to next message
I can't find what polarity I need to wire the 4Pi pro crossover. I thought in a 12db crossover you would reverse the drivers but in this circuit I'm not sure.
Kelly
Re: Four Pi Pro Polarity [message #38620 is a reply to message #38618] Thu, 10 October 2002 20:27 Go to previous messageGo to next message
Hook 'em straight, plus-to-plus. If you reverse the connection of one of the drivers, there is a noticeable dip in response. You might not notice it by ear, because the dip is narrow, a very thin notch. But it is immediately obvious when measured.
So... [message #38622 is a reply to message #38620] Thu, 10 October 2002 20:50 Go to previous messageGo to next message
On a 2226 I would hook red to black and black to red or.......black to....just kidding ....but the 2226 among other is backwards colorwise..correct?
Kelly
Handy reference documents [message #38623 is a reply to message #38622] Thu, 10 October 2002 21:52 Go to previous messageGo to next message
That's right.
JBL used a standard for many years that provided for positive pressure when a positive voltage was applied to the black terminal, which most consider to be the negative post. But since both the 2426 and the 2226 are this way, all components in the system will be phased as expected, when red is connected to red.
But if you're connecting other systems at the same time, this is important to know. There's a handy chart of JBL speakers and conection methods that is included in Professional Series π Speaker kits, and you'll also find it online in the "JBL Polarity Notice" document. Other useful documents that are included in the kits but not sent with E-Mailed plans are the "General Tips" and the "Crossover Connection Tips" documents. These are all small files, so downloads are quick.
PSD2002 [message #38625 is a reply to message #38623] Fri, 11 October 2002 10:04 Go to previous messageGo to next message
I'm using the Eminence driver so the + wire (red) will go on the black terminal on the 2226H....correct?
Kelly
Re: PSD2002 [message #38626 is a reply to message #38625] Fri, 11 October 2002 10:15 Go to previous message
The red (+) wire is positive on the PSD2002. Positive voltage on this terminal provides positive pressure, same as the black terminal on the JBL 2226. So you'll connect black to red when combining these drivers.
Previous Topic: where is the bass for my Beta 12 LTA
Next Topic: Studio Two Plans
Current Time: Thu Nov 19 17:17:51 CST 2026
