Home » Sponsored » Pi Speakers » Test
Test [message #38590] Tue, 08 October 2002 19:20 Go to next message
here goes.
Kelly
Re: Test [message #38591 is a reply to message #38590] Tue, 08 October 2002 19:21 Go to previous messageGo to next message
Well that didn't work!!!!!!
cold front moving in? [message #38596 is a reply to message #38591] Tue, 08 October 2002 20:14 Go to previous messageGo to next message
hey luxmanlover, you're in the prairies right? are you running any luxman?
cheers,
george
Uploading images [message #38597 is a reply to message #38591] Tue, 08 October 2002 20:21 Go to previous messageGo to next message
It looks like you were trying to post a pic, so maybe I can help.
Put your image somewhere on the net and then link to it. For example, if you can FTP your image file to www.TuPics.com or wherever, then you can link to it using its fully qualified URL address.
For example, if the image file you upload is named "www.tupics.com/images/button1.gif", then you will simply link to it using that name. Be sure to prefix it with "http://", so that the full thing you type in is "http://www.tupics.com/images/button1.gif". The required format is very specific, so the "http://" and the full and complete URL address is very important.
There's a chill in the air! [message #38599 is a reply to message #38596] Tue, 08 October 2002 21:12 Go to previous messageGo to next message
Yup I'm in Saskatoon and you're right summer is coming to a close unfortunately. As far as gear goes, I've got a Luxman C-1010 Pre-amp, T110 Tuner and a monster M-6000 power amp and my MonoPi4 Pro.
Kelly
Re: There's a chill in the air! [message #38600 is a reply to message #38599] Tue, 08 October 2002 21:15 Go to previous message
hi kelly, you've gotta try some tubes. it's like removing another blanket!
cheers,
george
Previous Topic: Many thanks to Wayne and others here, pseudo 4pi pro is great
Next Topic: Building 2 Pi Towers - Part 2
Current Time: Wed Oct 21 20:34:02 CDT 2026
