Home » Sponsored » Pi Speakers » Updated 2 Pi's & 7 Pi Question
Updated 2 Pi's & 7 Pi Question [message #38452] Thu, 26 September 2002 15:30 Go to next message
I put my 2 Pi's back together after oiling the wood and installing the inductors. They are looking good and sounding good! I like the effect of the inductor- noticed the difference right away even though it's subtle. Makes it a little more refined in the middle but it still has the great dynamics and presence.
The Tried & True Oil finishes Till E. recommended gave a great look to the birch ply. It really brought out the grain and gave them a nice amber glow. I didn't use any stain, just the oil finishes.
Wayne, how high does the wall have to be to use the Pi 7's? I have an area in my basement that has a granite wall on one side about 7 feet tall, and on the other side there's a brick wall that's about 3 feet high. I could finish it off into a room, but then both of the new corners would have a stud/drywall, and the brick wall would have drywall above 3 feet. I'd also have to put a door in which would be close the speakers. Any chance?
7 Pi Answer [message #38455 is a reply to message #38452] Thu, 26 September 2002 16:02 Go to previous message
Hi Matts!
I suggest you take existing speakers and point them into the corners. For this listening test, the tweeters will be pointed in the wrong direction, so don't let that fool you. Listen primarily to the bass and midbass, and listen for the quality and uniformity of response. If you like what you hear, then the corner is satisfactory and you can start cutting wood!
Wayne
Previous Topic: Delta 12LF with KSN 1038
Next Topic: Sheet goods program
Current Time: Sun Nov 08 07:43:01 CST 2026
