Home » Sponsored » Pi Speakers » 1pi port answer
1pi port answer [message #38406] Mon, 23 September 2002 10:46
Port length should be as shown on the plans. If you make the cabinet with thicker wood, just keep the internal box volume the same. The port diameter and length should also be the same, and port length is measured from entrance to exit. So if you have an existing box that's correct in all dimensions - and then you add a panel to the front - you should trim the back of the port so that it's total length from entrance to exit remains the same.
Previous Topic: 1pi port question
Next Topic: Speakers 101
Current Time: Thu Nov 26 10:51:24 CST 2026
