Home » Sponsored » Pi Speakers » alpha 10A frequency response
Re: Who could forget the "live, naked resistors"? [message #38353 is a reply to message #38350] Wed, 18 September 2002 17:34 Go to previous messageGo to previous message
The coil is now included with kits, so nothing else is needed. If you're doing your own, just install a 0.5mH coil in series with the woofer. Cut one of the wires going to the woofer and splice the coil in, covering the leads with heat shrink tubing.
The coil should use 20 guage or larger wire, which will result in less than 0.5 ohms DC resistance. A suitable part is the 260-723.This part has 0.5 ohms DC resistance, so the woofer's Qes is only raised by 0.03. The difference in overall system Q is small, so it works pretty well.
Previous Topic: Studio 1 pi plans
Next Topic: Is They Is Or Is They Ain't Horns
Current Time: Thu Nov 26 09:43:10 CST 2026
