Home » Sponsored » Pi Speakers » Pi 4 with 2226h plan request.
Pi 4 with 2226h plan request. [message #38329] Wed, 18 September 2002 04:05 Go to next message
Scholl is currently offline  Scholl
Hi could I get the plans for the Pi 4s that use the 2226h? I want to try to employ the high pass crossover on my Selenium 205ti, Klipsch 604 compination.
Also has anyone had any luck crossing the 2226h over below 1khz?
Thanks, Scott schollaudio@hotmail.com
selenium says min. xover is 1200Hz. [message #38334 is a reply to message #38329] Wed, 18 September 2002 08:10 Go to previous messageGo to next message
for the 205Ti driver. The fr chart shows them starting to drop off in level below 1.2 or 1.5kHz., down at least 4dB by 1000Hz, probably horn flare dependent to some degree, the ferro fluid should help when operating closer to Fs(did not notice the spec) by damping the resonance some. The 4 Pi Pro's run the 2226H's out to 1.6kHz. without problems, why not just cross at 1.2kHz/12dB/octave like selenium says? Sam
You've got mail! [message #38338 is a reply to message #38329] Wed, 18 September 2002 11:18 Go to previous messageGo to next message
Please try this [message #38347 is a reply to message #38338] Wed, 18 September 2002 16:04 Go to previous messageGo to next message
Re: Pi 4 with 2226h plan request. [message #38348 is a reply to message #38329] Wed, 18 September 2002 16:35 Go to previous messageGo to next message
Ciscokid is currently offline  Ciscokid
Hi,
Just wondering how would this combination work with a SET amp running a maximum of 8 watts?
Best regards,
ck
"Tube friendly" speakers [message #38351 is a reply to message #38348] Wed, 18 September 2002 17:12 Go to previous messageGo to next message
Some people find the Professional Series a little thin with SET amps under 10 watts. Others find they work just fine, so I suppose it depends on what amp you're using. For low power SET's, you generally can't go wrong with Theater Series four or seven π, or the Studio or Thermionic Series speakers.
Re: Pi 4 with 2226h plan request. [message #38388 is a reply to message #38348] Sat, 21 September 2002 04:07 Go to previous messageGo to next message
I've used the 2226h in 3.5 cubic ft box with SETs from 1 watt to 18 watts with good results. However a 55 watt 6550 P-P is incredable!!!
My complaint with the 2226hs is the midrange more than bass. They have very smooth flat midrange but a little dull sounding at low levels. It takes a few watts to liven them up.
I would recomend a 15 watt P-P 6B4G as the starting point. If you can't play music that loud consider a livelier speaker. The PI 2s look good also Hammer dynamics get good press.
Re: Please try this [message #38389 is a reply to message #38347] Sat, 21 September 2002 04:08 Go to previous message
Sorry, for the email problems. I can't clear anymore out. I'll give you a new Email next week.
Previous Topic: Two pi: Motorola tweeter help
Next Topic: Pi Hometheatre System
Current Time: Thu Nov 26 08:23:03 CST 2026
