Home » Sponsored » Pi Speakers » Is They Is Or Is They Ain't Horns
Is They Is Or Is They Ain't Horns [message #38314] Tue, 17 September 2002 07:12 Go to next message
Fresno is currently offline  Fresno
Are the Pi Corner Horns really "Horns" or are they somekind of a horn arrangement of a bass reflex speaker? I am new to this stuff but the web page shows the same driver for the horns as the bass relex.
Fresno
Biggest horns you can fit in a room. [message #38316 is a reply to message #38314] Tue, 17 September 2002 12:44 Go to previous messageGo to next message
I suppose this is sort of like the question of whether a horn is an acoustic impedance matching device or simply defines a fractional radiating space. But no matter how you look at it, the expansion of a room's corner forms a conical horn, as much a horn as any other. The area expansion is equivalent to a rectangular horn with 70o flare. See the schematic diagram in the post called "Cornerhorns".
Re: Biggest horns you can fit in a room. [message #38321 is a reply to message #38316] Tue, 17 September 2002 15:27 Go to previous messageGo to next message
On this page on your website it shows the same LF motors for your bass reflex as well as your corner horns:
http://www.pispeakers.com/AvailableComponents.htm#Theater
Isn't a horn a different type of speaker or am I misunderstanding things?
Re: Biggest horns you can fit in a room. [message #38322 is a reply to message #38321] Tue, 17 September 2002 16:01 Go to previous messageGo to next message
You can put a horn on any loudspeaker. In fact, you can use a horn with no loudspeaker at all, such as is the case with a megaphone. A horn is just an acoustic device that directs a sound wave. As a consequence, it also modifies acoustic impedance.
Re: Biggest horns you can fit in a room. [message #38324 is a reply to message #38322] Tue, 17 September 2002 18:20 Go to previous messageGo to next message
Wayne,
I had the wrong mental picture of what a horn is. Thanks for your patience.
Can horns be designed for "source accurate" imaging?
Re: Biggest horns you can fit in a room. [message #38325 is a reply to message #38324] Tue, 17 September 2002 20:22 Go to previous messageGo to next message
A horn is a device having an entrance (throat), passageway (flare) and exit (mouth). So horns are made by bringing a megaphone-like device in near proximity to loudspeaker diaphragm. The system is usually sealed so the radiated sound has to pass through the horn with no leaks. In the case of the π cornerhorn, the horn for the woofer is formed by the walls of the listening room, itself.
Re: Biggest horns you can fit in a room. [message #38330 is a reply to message #38325] Wed, 18 September 2002 05:03 Go to previous messageGo to next message
I thought that the horn was a replacement for the cone of the driver. I don't know how it would move enough air to get the low freqs, but there is a lot I don't know.
Re: Here's an image.... [message #38333 is a reply to message #38330] Wed, 18 September 2002 07:05 Go to previous messageGo to next message
I think this is made in Japan and is very expensive...
TQWP? [message #38335 is a reply to message #38333] Wed, 18 September 2002 09:15 Go to previous messageGo to next message
JLapaire is currently offline  JLapaire
Kind of hard to tell the scale to guess at the cutoff, but that looks like a 40 or 50 hz Tapered Quarter Wave Pipe bent to look like a sax. Cool, but not really a horn.
John
Re: TQWP? Yes, and good visual pun! n/t [message #38336 is a reply to message #38335] Wed, 18 September 2002 09:46 Go to previous messageGo to previous message
n/t
Previous Topic: alpha 10A frequency response
Next Topic: Help! I'm looking for crossover suggestions for JBL 2445/2446 compression drivers!
Current Time: Thu Nov 26 09:18:29 CST 2026
