Home » Sponsored » Pi Speakers » 2 Pi's completed
2 Pi's completed [message #38304] Mon, 16 September 2002 18:29 Go to next message
Hi Folks,
After forever, I've finally finished a set of speakers my wife
would let in the house. These are slightly oversized 2 Pi's with
KSN1165's instead of the KSN1038's. They are made from birch plywood
and solid walnut. The finish is tung oil, a mix of tung, poly, and thinner, blonde shellac, and paste wax. The wife still wants grill cloths installed, I'm stalling but will eventually conceed. The Alpha-10 is crossed over around 2K. Here's the URL:
http://12.246.10.170:1280/woodworking3.html
BTW, they sound pretty darn good and there's not much lacking for when it comes to bass. Those Alpha 10's are a great deal. They don't
match the bi-amped JBL 3677's in the garage, but are really nice for
the bedroom.
Thx Wayne!!!
Chris
Re: 2 Pi's completed [message #38305 is a reply to message #38304] Mon, 16 September 2002 19:35 Go to previous messageGo to next message
Super way to leave the walnut proud of the cabinet. Tough to convince most people it looks better that way than flush.
How did you decide to combine all those ingredients in the finish? No problem getting the Tung to combine with the poly? Or did you do it in layers?
They really look great. The trim in picture frame fashion gives you a great way to add the grilles when you're ready. Parts express has good cloth for the purpose; Antique Electronic (tubesandmore.com) has vintage stuff, way cool.
Re: 2 Pi's completed [message #38306 is a reply to message #38304] Mon, 16 September 2002 19:43 Go to previous messageGo to next message
Bugman is currently offline  Bugman
Nice Job!
Re: 2 Pi's completed [message #38307 is a reply to message #38304] Mon, 16 September 2002 19:46 Go to previous messageGo to next message
cary is currently offline  cary
Way cool! Thank you for sharing the pixs!
Re: 2 Pi's completed [message #38308 is a reply to message #38304] Mon, 16 September 2002 21:53 Go to previous messageGo to next message
Great job - Really attractive!
Thanks for posting the pics on your website!
Re: 2 Pi's completed [message #38309 is a reply to message #38304] Tue, 17 September 2002 03:17 Go to previous messageGo to next message
JLapaire is currently offline  JLapaire
The extra work sure paid off visually! The darker "borders" lend a very substantial look.
Although they may not stand up to the giants in the garage, if you A-B them with the vast majority of commercial speakers out there you'll feel justified in taking the time to make them beautiful.
Nice work.
John
Re: 2 Pi's completed [message #38311 is a reply to message #38304] Tue, 17 September 2002 06:29 Go to previous messageGo to next message
spkrman57
Chris,
Nice job on the cabinets! You say you crossed the Alpha 10's over at 2khz, what crossover did you use, and if I may be nosy, why the 1165's instead of the 1038's????
Thanks, Ron
Re: 2 Pi's completed [message #38312 is a reply to message #38311] Tue, 17 September 2002 07:00 Go to previous messageGo to next message
Thanks. The crossover is a 12dB. I think a .8mH coil and a
10uF cap. The speakers are a little bright around 2K, so it
probably needs shifting down a little. As for the tweeters, I have
both and favored the 1165's for the extra midrange. It was also
partly fear of the hump in the A10's around 4.5K. I can't complain.
Re: 2 Pi's completed [message #38313 is a reply to message #38305] Tue, 17 September 2002 07:10 Go to previous messageGo to next message
Its this way mostly because it was easier than flush and once the
grill are in place, it will be a flush front with the nice frame.
Its in layers. Actually, the initial coat was the tung, poly, thinner
mix on the front and bottom. Plain tung on the rest. It sat a week
while I was out of town, and when I got back, the rest sort of had
the grain raised. Not bad but it wasn't as smooth as it was. The
front and bottom were still smooth. I did a coat of the mix again
on the whole thing (after some light sanding). I'm not real happy
about how it goes on. Its doesn't seem to stay mixed, but once wiped
off, it feels nice and drys just fine overnight. Next was two coats
of shellac brushed on. Again, not a perfect job, but you have to
look close. A little steel wool, and wipe, and the wax. The waxing
adds a nice warmth and evens out the sheen and feels great.
I have maybe 5 yards of the black from PE. I can't remember what I
was smoking when I placed the order. 5 yds is a huge amount. Now
I'm thinking something the color of the birch from AE might be
nicer.
Thx, Chris
Re: 2 Pi's completed [message #38323 is a reply to message #38304] Tue, 17 September 2002 17:20 Go to previous messageGo to previous message
Sharp lookin cabinets. Always liked two tone and corner blocking.
Very nice job.
Bill Martinelli
Previous Topic: Help me! What to do about 2Pi port
Next Topic: Studio 1 pi plans
Current Time: Fri Sep 27 08:27:14 CDT 2024
