Home » Sponsored » Pi Speakers » 8 ohm & 4 ohm
8 ohm & 4 ohm [message #38296] Fri, 13 September 2002 15:26 Go to next message
Zeno is currently offline  Zeno
can i use a 8 ohm woofer and a 4 ohm tweeter together?
Re: 8 ohm & 4 ohm [message #38297 is a reply to message #38296] Fri, 13 September 2002 17:09 Go to previous message
Hello Zeno!
Yes. Only the crossover will care; Maybe the amplifier too. There are things to consider with the crossover filters and you should understand the loads presented and how they will be translated into power and efficiency. But there is nothing terribly wrong with using these together as long as you've taken all this into account.
Wayne
Previous Topic: 2 Pi Towers
Next Topic: L Pad & Trimmer
Current Time: Fri Nov 13 19:23:21 CST 2026
