Home » Sponsored » Pi Speakers » Reconing JBL D130's
Reconing JBL D130's [message #38203] Thu, 05 September 2002 20:30 Go to next message
Coner is currently offline  Coner
Have a few D130 (alnico) frames sitting here, what do you guy's
recommend I recone these as? Say, which for a
Re: Reconing JBL D130's [message #38208 is a reply to message #38203] Fri, 06 September 2002 12:34 Go to previous messageGo to next message
I usually recone with the genuine original kit, unless it isn't available. The D130, D130F and D130H use the JBL recone kit C8RE130, and the D130F-16 uses the C16RE130 kit. See the "where used" document below.
You might call David Miller at Speakerworks in Tulsa, (918) 664-6299. He's authorized by JBL, keeps most reconing kits in stock and he's really good.
Wayne
Re: Reconing JBL D130's [message #38214 is a reply to message #38208] Sat, 07 September 2002 12:54 Go to previous message
Looks like 2235 is best bet for small ported. Now, what's
the best for horn loaded (A-7) cab.? I will be using genaric
cone kits like waldom.
Problem with the "keep original" idea is I have no use for
a M.I. speaker (D130).
Previous Topic: Thanks for the great service
Next Topic: yeehaw, no smoke came out
Current Time: Wed Oct 28 23:56:03 CDT 2026
