Home » Sponsored » Pi Speakers » frosting on the pi
frosting on the pi [message #38165] Wed, 04 September 2002 09:21 Go to next message
tdc is currently offline  tdc
The JBL tent sale has 2402H drivers with 16 ohm 2405 diap. This per tech support is good for 6500 to 21500 cps. If I get an extra pair for the 4 pi (pro with Jbl drivers and a 2345 horn) where would one bring it on board (cross over point) tdc
Re: frosting on the pi [message #38168 is a reply to message #38165] Wed, 04 September 2002 12:31 Go to previous messageGo to next message
I'd remove the compensation circuitry from the 2426 and crossover to the 2402 somewhere around 6.5kHz - 8kHz.
Re: frosting on the pi [message #38170 is a reply to message #38168] Wed, 04 September 2002 13:23 Go to previous messageGo to next message
Wayne, you mean you and others did all that series-parallel explanation to me for nothing! I guess I could enter the resistor necklace in a art show. Seriously, if I lose the necklace would I use a first order both ways at 8000 cps. tdc
Re: frosting on the pi [message #38171 is a reply to message #38170] Wed, 04 September 2002 15:25 Go to previous messageGo to next message
You might keep the tweeter's compensation cable assemply; That way, if you ever want to put it back and run the system that way again later, you'll have it built and ready to go.
Re: frosting on the pi [message #38172 is a reply to message #38171] Wed, 04 September 2002 15:29 Go to previous messageGo to next message
Wayne, I intended to keep it and try both arrangements. How could I sell anything it took so long to fiqure out. I still wonder if you have a recommendation about the slope for the 8000 cps x-over? tdc
go with jbl's advice and [message #38173 is a reply to message #38172] Wed, 04 September 2002 15:57 Go to previous messageGo to next message
cross using a 12dB/octave filter. Remember, those tweets are described as "tight pattern control, deep penetration, and extremely high ON-AXIS sensitivity". Your upper freqs are going to be in a narrow 40 degree beam...is that OK in your listening situation? Might want to look for some 2404's (the baby cheek tweets) that are wider dispersion. A search at HUG for jbl 2402 will also turn up some suggestions from previous users, IIRC. Sam
Re: go with jbl's advice and [message #38174 is a reply to message #38173] Wed, 04 September 2002 16:10 Go to previous message
Thanks. I didn't know JBL had suggestions but will look for old posts. The narrow pattern is something I was concerned about. The Coral bullet ( H-70) in my Hitachi Hs-500 is equipped with a set of fins to spread the sound field. That idea was also used with the JKL potatoe masher so I thought I would give it a try.tdc
Previous Topic: physics of port tuning
Next Topic: PSD 2.8 speaker
Current Time: Sun Oct 25 04:47:13 CDT 2026
