Home » Sponsored » Pi Speakers » Is this why JBL 2245 was discontinued ?
Re: Differences between 2241 and 2245? [message #38156 is a reply to message #38155] Tue, 03 September 2002 17:46 Go to previous messageGo to previous message
Anonymous
three things on my mind - lol
#1 Is there a correlation between a woofers x-max rating and
"tight bass" ? if you know what I mean (loose suspension and tight
suspension). Do "tight coned" woofers sound better than "subwoofers",
or is this just a myth?
#2 Is there a correlation between a woofers voice coil diameter and
"tight bass" and/or sound quality assuming similar woofers?
or is the voice coil just a function of power handling,
not sound quality ? ie, if JBL made a woofer with a 2" voice
coil would it sound as good/bad as the same one using a a 4" dia
voice coil ?
#3 What factors do you look at when trying to find a woofer
with a strong motor ?
Previous Topic: Question for the carpenters out there
Next Topic: physics of port tuning
Current Time: Thu Oct 29 14:31:28 CDT 2026
