Home » Sponsored » Pi Speakers » Best speaker for subwoffer
Best speaker for subwoffer [message #38058] Mon, 26 August 2002 11:34 Go to next message
JBLman is currently offline  JBLman
I have a chance to pick up either the 2241H or 2245H, however the 2241's are more expensive. Is the 2245, which is designed for low frequency, a suitable speaker for a Pi-subwoofer??
Re: Best speaker for subwoffer [message #38059 is a reply to message #38058] Mon, 26 August 2002 12:00 Go to previous messageGo to next message
Will2k is currently offline  Will2k
in my opinion the 2242h is the best one can do for a subwoofer speaker.
Will
Re: Best speaker for subwoofer [message #38060 is a reply to message #38058] Mon, 26 August 2002 14:15 Go to previous messageGo to next message
The 2241 is JBL's most popular 18" product and it's pretty easy to find. The 2242 is their latest offering and it is capable of greater output but not quite as deep extension. Both are commonly used in cabinets having EBS alignments. The 2245 is tuned for greater bass extension. It is excellent for use as a high-fidelity subwoofer.
Re: Best speaker for subwoffer [message #38062 is a reply to message #38058] Mon, 26 August 2002 15:17 Go to previous message
D. Kurfman is currently offline  D. Kurfman
The 2245 has superior parameters for true subwoofer performance. You will need a very large box to take full advantage of it. The 2242 will give very hi power handling but is more a woofer than subwoofer. There was an article titled "Certifiable bass for the certifiable" in Audio magazine several years ago showing what duall 2235 drivers can do when each driver is in a 10 cubic foot cabinet tuned to 20 hertz. The same kind of performance is posible with the 2245 ussing a 16 cubic foot box. Properly praced and tuned, this will eat most so called subwoofers for lunch. It should only be used for about 2 octaves when used this way. When using a more conventional tuning it can be used as a wider range driver.
Dan
Previous Topic: 2 Pi plans
Next Topic: Tis a sad, sad day my friends...
Current Time: Fri Nov 13 06:43:44 CST 2026
