Home » Sponsored » Pi Speakers » Active X user's, system set up
Re: It works well [message #38001 is a reply to message #37993] Thu, 22 August 2002 16:43 Go to previous messageGo to previous message
You can definitely make your system sound better using the EQ on this.
It also lets you set right and left channels independently from one and other. Its a very nice unit and you cant beat it for the money. It's really a good deal.
I found that using adaptors like an RCA to 1/4" was really bad. I may have had bad ones but I was surprised by this. Get a cable that RCA on one end and 1/4" on the other. This will help.
It is really pretty quiet. I would describe the noise I'm getting as similar to the hiss you hear from compression drivers. It's not as loud as that though. and you certainly cant hear this unless your head is in the speaker. This could also be something related to my system.
hope this helps,
Bill
Previous Topic: JBL EBS alignment?????
Next Topic: Tweaking speaker cabinet size
Current Time: Fri Nov 06 06:12:58 CST 2026
