Home » Sponsored » Pi Speakers » Dagnabbit Wayne!
Dagnabbit Wayne! [message #37980] Thu, 22 August 2002 11:56 Go to next message
It's my day off and a friend offered the use of his shop while he's on vacation. So I go over there and butcher up sme MDF for my custom 2 Pi, time aligned speaks. Boy, can you turn out the work ina properly equipped shop! 2 1/2 hours and there ready to venner.
But I come home, log on and here's the news that you've designed a
#$@&%#*& Tower?
I hope my sloped baffle sounds decent, I did a seatofthepants calculation on volume and it wound up 25" high.
The website has the dimension wrong; 46X15X? And I assume the port is different?
Re: Dagnabbit Wayne! [message #37981 is a reply to message #37980] Thu, 22 August 2002 12:04 Go to previous messageGo to next message
Erik Johansson is currently offline  Erik Johansson
The dimensions, as Wayne stated somewhere in the forum earlier today or yesterday are: 46x16x13 built from 5/8" stock. The port is a 4.5 inch hole through the 5/8" stock on the back of the speaker.
It can be found a little further down under the "2 Pi and 1 Pi closeness to wall placement question" topic.
/Erik
Re: Dagnabbit Wayne! [message #37984 is a reply to message #37980] Thu, 22 August 2002 12:39 Go to previous messageGo to next message
Oops - You're right. The dimensions are shown correctly on the plans but the description on the website is wrong. I'll correct that ASAP.
More ideas [message #38089 is a reply to message #37980] Wed, 28 August 2002 13:15 Go to previous message
Post some pictures, if you would. I'd love to see your influence on the design. I still think your two-tone Theater four π's are some of the most attractive goin'!
Previous Topic: tower two plans
Next Topic: So much for buying local!!!
Current Time: Fri Oct 30 10:48:24 CDT 2026
