Home » Sponsored » Pi Speakers » 2 Pi and 1 Pi closeness to wall placement question.
Low-end on these new towers [message #37967 is a reply to message #37958] Thu, 22 August 2002 04:58 Go to previous messageGo to previous message
Erik Johansson is currently offline  Erik Johansson
How would you rate the low-end on these Two Pi towers compared to the Thermionic 3 Pi that I was thinking of building before I heard about this? I'd love to see some response curves (I'm trying to master Boxplot!) comparing them.
I'll play around some more with Boxplot, maybe I'll get it right :)
You recommend to put them in the corners. Would my corner where part of the ceiling is angled 45 degrees against the left side wall be ok? At its lowest point (against the side wall) the ceiling is down to 122cm height? The speakers are 116cm high so they would really be "in the corner", if you know what I mean.
This I my only option, so I hope it's ok.
/Erik
Previous Topic: 2 Pi Tower Speaker Plans
Next Topic: Who is close to Omaha, Nebraska
Current Time: Fri Nov 06 05:34:36 CST 2026
