Home » Sponsored » Pi Speakers » eminence psd-2002 vs selenium d300ti
eminence psd-2002 vs selenium d300ti [message #37930] Wed, 21 August 2002 10:31 Go to next message
wow, check out how massive the selenium driver is. i'm planning on using this with the selenium wpu1505 woofer and the hm39-35r horn in a selenium version of wayne's 4 pi pro. i'm very impressed with the build quality of their product and especially like the look of the horn. wayne, i'll send you the spec's so you can tell me if it works.
cheers,
george
selenium wpu1505 woofer photo [message #37931 is a reply to message #37930] Wed, 21 August 2002 10:34 Go to previous messageGo to next message
nice & solid
selenium horn [message #37932 is a reply to message #37930] Wed, 21 August 2002 10:40 Go to previous messageGo to next message
this has a 1.4" throat and matches to the d300ti 1.4" motor. 60x30 dispersion with a lf limit of 500hz. the material is fiberglass.
Good stuff! [message #37933 is a reply to message #37931] Wed, 21 August 2002 11:13 Go to previous messageGo to next message
That's good stuff! Brian Jefferys made some Professional Series seven π's with the same Selenium parts and reported excellent performance. From what he said, they're very nice.
Re: Good stuff! [message #37938 is a reply to message #37933] Wed, 21 August 2002 12:32 Go to previous messageGo to next message
thanks wayne, i'll go ahead and build them according to 4 pi pro plans. please forward the plans.
cheers,
george
You've got mail! [message #37939 is a reply to message #37938] Wed, 21 August 2002 13:54 Go to previous messageGo to next message
Specs show the same box tuning is appropriate, and as I recall, Brian was more than pleased with their sound.
Here are Brian's posts [message #37942 is a reply to message #37933] Wed, 21 August 2002 16:53 Go to previous messageGo to next message
Here are Brian's posts about his seven π's with Selenium parts.
Re: eminence psd-2002 vs selenium d300ti [message #37943 is a reply to message #37930] Wed, 21 August 2002 17:10 Go to previous message
thats a mighty big driver ya got there meester.
Looks like some good stuff. please tell how it sounds when finished.
Previous Topic: 2nd ordrer Butterworth vs 3rd order Butterworth
Next Topic: Effects of horn loading
Current Time: Wed Oct 21 04:18:28 CDT 2026
