Home » Sponsored » Pi Speakers » JBL 2344 Bi-Radial Horn Vs Tractrix Vs Exponential
JBL 2344 Bi-Radial Horn Vs Tractrix Vs Exponential [message #37864] Sun, 18 August 2002 12:12 Go to next message
spncer is currently offline  spncer
I read with interest your post comparing the Tractrix and Exponential horns. How do these designs compare with the 2344 horn in terms of off axis response, 2nd and 3rd harmonic distortion?
Thanks Spencer
Re: JBL 2344 Bi-Radial Horn Vs Tractrix Vs Exponential [message #37867 is a reply to message #37864] Sun, 18 August 2002 13:11 Go to previous message
Please see the JBL 2344 specifications sheet. You might also look at the spec sheets for the 2426 and 2446 compression horns, which show response of these devices when mounted on the 2370 and 2380 horns. And finally, JBL Tech Notes, Volume 1, Number 7 is specifically written about flat-front radial horns and their performance in arrays.
Previous Topic: Bonus!!!!
Next Topic: Thermionic 3 Pi with Yuichi Arai's A-480 woodhorns
Current Time: Tue Oct 20 06:48:50 CDT 2026
