Home » Sponsored » Pi Speakers » Resistor attenuation
Resistor attenuation [message #37761] Sun, 11 August 2002 14:16 Go to next message
Jerry Parker is currently offline  Jerry Parker
Hey Wayne, Mitch and I listened to the 4pi's A LOT this weekend, playing lots of music and like 3 movies. I have come to this conclusion. They sound perfect on movies, no changes needed. They also sound perfect when played outdoors, the bass is amazing. But the odd thing is, when inside when playing music, it seems that they have too much midrange, and the bass and treble is too rolled off. Obviously changing the reisistor block out, we can fix the problem with the treble, and the bass isnt a problem, since Mitch has a subwoofer. I dont have the plans in front of me right now, but what are the resistor and capacitor values needed for 14dB of attenuation vs the standard 10dB? I figure he might as well build the alternate tweeter filter, just to see which he likes better. I personally think I would like the 14dB attenuation better, since they will be used primarily indoors. But when used outdoors, the stock configuration works perfect! Do you have any other suggestions? Thanks again Wayne!
Also, we will probably put the veneer on the speakers this wednesday, so you could probably come over and hear them sometime after that. Let me know your schedule.
Re: Resistor attenuation [message #37763 is a reply to message #37761] Sun, 11 August 2002 16:12 Go to previous message
Generally, speakers like this sound a little bass-shy in large rooms or outdoors. That's why subwoofers are often used. Indoors, they usually sound pretty balanced, although subwoofers are sometimes still employed to smooth room modes.
My guess is that your room is pretty lively, either hardwood paneling or glass and not a lot of furniture. In that case, I would suggest just turning the treble down a notch, but you can also do that by modifying the crossover to attenuate the tweeter a little more. The schematic included in the plans show a chart of values for various levels of attenuation. The 10dB unit has R1=16, R2=16 and C1=0.47, the 12dB unit has R1=25, R2=16 and C1=0.47 and the 14dB unit has R1=30, R2=14 and C1=0.33uF. You could install the 12dB or 14dB values.
Previous Topic: Link to Bottlehead post on paramour re-build
Next Topic: speaker material-oak plank??
Current Time: Thu Nov 05 17:24:15 CST 2026
