I took my own advice and got a new router. Oh Yeah! [message #37576] |
Tue, 30 July 2002 12:05 |
BillEpstein
Messages: 886 Registered: May 2009
Illuminati (2nd Degree) |
Got the Freud FT 2000E I touted a while back. I had it's predecessor way back in 198x something. In a time when Porter Cable is now cheap shit, the Freud, for $179 has soft start, 5 speeds, one wrench collet lock and 15 amps. It is a beast, though. I'll still be using my old Rockwell for rabbets and roundovers. The base casting is even powder coated! It still has the same nice height adjustment with a great big knob that sticks up above the motor. That's good news-bad news: it means you have to set it on the edge of the bench to change bits but the knob is real easy to find and turn under a router table. I'm pretty sure, after John Atkinson finishes the measurements, it will be Class A. And International Tool has free shipping.
I have......... [message #37580 is a reply to message #37577] |
Tue, 30 July 2002 15:03 |
BillEpstein
A P-C belt sander, 690 router, Rockwell (became P-C) router,P-C RO sander and a P-C 12 volt cordless drill. Check your new sander against my 20 year old like I did the 2HP router I bought and returned. The casting is a cheap POS and look at your platen, it's a thin POS. Now take a really accurate Starrett square to the frame the platen rides on, You'll have to spend an hour truing it! MWAHAHA! You won't have bar top sander races with this generation of sanders. The motors look like they came from Suzuki windshield wipers. And the bearing in the latest production routers? Forget it. The drill is 2 years old the plastic housing is cheap and something already is rattling around in there. I bought nothing but P-C for over 30 years because it was the best. Now it's krap made by the People's Liberation Army Workshops.No mo' Porter Cable for me.
So whats.... [message #37582 is a reply to message #37580] |
Tue, 30 July 2002 15:16 |
LuxmanLover
Messages: 164 Registered: May 2009
Master |
point? LOLOLOLOLOL Well....what can I say. Your probably right....the stolen stuff was pretty old and worked great. Have to replace with what you had.........hhhhmmmmmmmm where were you 3 thursday nights ago? Kelly
