Home » Sponsored » Pi Speakers » Wayne, recommendation please...
Wayne, recommendation please... [message #37543] Sun, 28 July 2002 10:18 Go to next message
jsalve is currently offline  jsalve
Hi Wayne,
I decided to give my PI-7's with 1602's to my brother, he has a much bigger room than I do, so it will work much better at his place.
So the question is, what to mate with it. He is willing to spend around US$500-700 for the horns and drivers. Can you please give recommendations?
I noticed you started selling horns and drivers, so I told him to buy these from you together with your crossovers.
Thanks for your help.
Jeff
Options [message #37544 is a reply to message #37543] Sun, 28 July 2002 13:49 Go to previous messageGo to next message
I'd suggest running a three-way, using a 90x40 conical horn loaded with a TAD 1101 or JBL 2123 for a mid and a TAD 2001 or JBL 2426 on a nice 90x40 horn on top. Another option would be to go with a TAD 4001, and run the crossover point down to meet the 1602.
Long lost brother. [message #37551 is a reply to message #37543] Mon, 29 July 2002 03:34 Go to previous messageGo to next message
Rider is currently offline  Rider
Hi Jeff.
I just found out we're long lost brothers.
If you happen to have a second pair of Pi 7's running TAD ......
Grant.
Re: Options [message #37560 is a reply to message #37544] Mon, 29 July 2002 14:09 Go to previous messageGo to next message
D Kurfman is currently offline  D Kurfman
Wayne,
Have you worked up a cross-over for either of the above horns with the 2123h?
Re: Options [message #37561 is a reply to message #37544] Mon, 29 July 2002 14:49 Go to previous messageGo to next message
Thanks for the info Wayne.
We're leaning towards a simple 2 Way to minimize cost. So for horn flare we'll go with your recommendation and will go with Eminence 2". That leaves us a good chunk of the budget for the compression driver. We'll keep an eye on the used market for a 2" compression drivers.
Yeah, I wanted to order from the tent sale, lots of good deals there. But unfortunately they don't sell to Canada.
Thanks,
jeff
Re: Long lost brother. [message #37562 is a reply to message #37551] Mon, 29 July 2002 14:52 Go to previous messageGo to next message
Oh-uh, another brother. My dad is already in big enough trouble with my mom.
Better keep this to ourselves, OK? :)
Regards Bro?
Jeff
Re: Options [message #37565 is a reply to message #37560] Mon, 29 July 2002 16:05 Go to previous messageGo to next message
Yes, I have a crossover design for this configuration. In the 1980's, all my seven π loudspeakers were three-way designs similar to what I suggested to Jeff.
Re: Long lost brother. [message #37583 is a reply to message #37551] Wed, 31 July 2002 00:28 Go to previous message
I have TAD 1602's available if you're interested.
Previous Topic: I took my own advice and got a new router. Oh Yeah!
Next Topic: switching power supply used in amps
Current Time: Thu Nov 12 23:21:16 CST 2026
