Home » Sponsored » Pi Speakers » Cornerhorns!
Acoustics and aesthetics [message #37441 is a reply to message #37438] Mon, 22 July 2002 13:09 Go to previous messageGo to previous message
My experience with typical homes - framed drywall construction, concrete slab and eight foot ceilings - Rooms from a few hundred square feet to around 1500 square feet having length/width ratio's between 1.5 and 1.7 to 1.0 work best. It's usually preferable acoustically to put the speakers across the short wall. This crosses the forward axis in the front half of the room, which usually provides the best imaging. See the post called "Making speakers disappear", for more discussion about that.
However, just like you, I've had a great deal of experience with placements other than that. Some put them across a long wall, some diagonally. Some are asymmetrical, and in oddly-shaped rooms. Often there are obstructions or disruptions, changes in wall construction or windows. As you might expect, some things are more objectionable than others.
So my best suggestion to you is to keep doing what you're doing. Get a spool of large guage stranded wire and go ahead and try them in each position and see what you like best. This is as important for aesthetics as it is acoustics, and so setting everything up and "living with it" for a few hours or days will help you decide. Probably the most pleasant placement will be self evident.
Previous Topic: A wierd question
Next Topic: Theater 4 Pi plans!
Current Time: Fri Nov 13 08:52:52 CST 2026
