Home » Sponsored » Pi Speakers » Wayne or anybody: L-pad values
Wayne or anybody: L-pad values [message #37321] Mon, 15 July 2002 15:34 Go to next message
Hey, I need resistor values for R1 and R2 for an Lpad, padding an 8 ohm compression driver down 18 decibels.
Yes, I know... It's terrible. It's for a buddy of mine to use temporarily until we can get him setup with an active xover.
Thanks guys.
Adam
Re: Wayne or anybody: L-pad values [message #37329 is a reply to message #37321] Mon, 15 July 2002 17:13 Go to previous messageGo to next message
Hi Adam,
I'll give it a shot with -18db=
R1= 50
R2= 12
Bill
Re: Wayne or anybody: L-pad values [message #37332 is a reply to message #37329] Mon, 15 July 2002 18:38 Go to previous messageGo to next message
Thanks man!
Adam
Re: Wayne or anybody: L-pad values [message #37337 is a reply to message #37332] Mon, 15 July 2002 22:28 Go to previous messageGo to next message
The values R1=50 and R2=12 are for the π crossover, which uses a bypass capacitor across R2. R1 is the "load" for the high-pass filter and R2 is a series attenuator. Capacitor C1 is placed across R2, and is 0.22uF for a 1.6kHz crossover and 0.66uF for an 800Hz crossover.
I say all this as a reminder that the three components are part of the filter formed also by the compression horn and the Butterworth crossover filter. The thing is designed to provide specific damping at the crossover frequency, so that the first couple of octaves are flat before augmentation starts. This is all outlined in detail in the π crossover document.
If you wanted just a flat attenuator with no compensation for the compression horn, you would choose R1 and R2 values that added to be approximately 8 ohms, but that acted as a voltage divider, cutting power to just under 2%.
Re: Wayne or anybody: L-pad values [message #37339 is a reply to message #37337] Tue, 16 July 2002 06:04 Go to previous message
Wayne, I don't need the compensation circuit, only the attenuation.
Long story, it's for a temporary network for a car horn. Doesn't need the attenuation because of the flare rate and whatnot.
Thanks dude.
Adam
Previous Topic: Building a pair of 2 Pi in solid pine?
Next Topic: i wanna feel the bass!
Current Time: Tue Aug 13 15:30:45 CDT 2024
