Home » Sponsored » Pi Speakers » Small sub
Small sub [message #37296] Sun, 14 July 2002 12:35 Go to next message
I'm toying with the idea of building a set of subs to use with the professionial 4Pi's I'm building. I would like to use the JBL 2235 in 4 cubic foot cabinets. My concern is how much of a performance compromise it will be using that driver in that size of cabinet. I would appreciate input from anyone with experience with this particular driver.
Kelly
PiAlign'ed 2235 [message #37300 is a reply to message #37296] Sun, 14 July 2002 14:22 Go to previous messageGo to next message
PiAlign recommends 4 cubic tuned to 30Hz with a 2.25" x 4" x 3.6" long rectangular port. You can also substitute a cylindrical port, 4" diameter and 4" long with excellent results. The system -3dB point is 37Hz and -10dB at about 27Hz.
Hmmmmm [message #37304 is a reply to message #37300] Sun, 14 July 2002 14:53 Go to previous messageGo to next message
I must not be using PiAlign properly...cause it said I needed 8 cubic feet for a 2235 (which is funny cause I actually want to use 2 2235's per cabinet for a total cabinet size of 8 cubic feet hehehehehe, it should be wild!)
Kelly
Re: Hmmmmm [message #37305 is a reply to message #37304] Sun, 14 July 2002 15:23 Go to previous messageGo to next message
For the JBL 2235H - Vad=16.2, Frd=20 and Qd=4.0. So when you enter all that into PiAlign, it suggests 4.0 cubic feet tuned to 30Hz.
Thx Wayne [message #37306 is a reply to message #37305] Sun, 14 July 2002 16:18 Go to previous message
Worked that time, must have entered the wrong value for vad (doh). 8 cubic feet makes me very happy!!!!!!
Kelly
Previous Topic: Extremely high output
Next Topic: box size for 2235
Current Time: Wed Nov 04 03:23:13 CST 2026
