Home » Sponsored » Pi Speakers » Hi Wayne: Mounting drivers
Hi Wayne: Mounting drivers [message #37281] Fri, 12 July 2002 22:53 Go to next message
Edwin is currently offline  Edwin
My 2Pi kit finally arrived today. What screw size do you use to mount the tweeters/drivers?
Thanks,
Edwin
Pan screws [message #37282 is a reply to message #37281] Sat, 13 July 2002 01:42 Go to previous message
I like using the screw mentioned below for mounting small and medium format drivers to the baffle. For that purpose, A pan screw as used for drywall is perfect. I used to hand paint the screws black, but now I use the 1" long #8 pan screws shown below, and get them from www.idxmart.com, part number 1F943-26637.
Fasteners: US Standard: Steel: Screws, Wood, Pan, Particle Board, Phillips, Type A Point, Black Finish
Seller: LGI
Part Number: 1F943-26637
Package Size: 100
Diameter: #8
Length: 1
Previous Topic: For corner horn lovers. Just a chuckle.
Next Topic: Crown (and other) amp power ratings
Current Time: Tue Oct 06 21:04:49 CDT 2026
