Home » Sponsored » Pi Speakers » Omega Pro 18, Box Volume
Omega Pro 18, Box Volume [message #37214] Mon, 08 July 2002 18:41 Go to next message
Kittikun is currently offline  Kittikun
Hi Wayne,
When I run Pialign, the recommend box volume is 3.3 cu.ft but from Pi web site, the box volume for stage 4 Pi-18 is the same as Therter 4 Pi around 8 cu.ft. Therefore I am a little bit confuse. What is the suitable box volume for the Stage 4 Pi-18? Please.
Best Regards,
Kittikun
Re: Omega Pro 18, Box Volume [message #37220 is a reply to message #37214] Mon, 08 July 2002 21:01 Go to previous messageGo to next message
A PiAlign'ed Omega 18 response curve is optimally flat, more so even than the larger box. But I like to put this speaker in a larger cabinet, using an EBS shelved alignment for use as a sub. The box is tuned to 30Hz, and what the response curve does in this alignment, is to drop about 3dB at 100Hz, and stay linear at this reduced level down to 30Hz. The PiAligned cabinet has no drooping response from 100Hz, but extension is only to 50Hz. Having a 50Hz -3dB point is certainly good for some situations. But if you want deeper bass extension, an EBS alignment becomes more attractive. That's why I prefer a larger cabinet for this woofer.
Re: Omega Pro 18, Box Volume [message #37243 is a reply to message #37220] Tue, 09 July 2002 18:57 Go to previous messageGo to next message
Hi Wayne!
What is the best sounding between Stage 4 PI-18 and Stage 4 PI using Omega Pro 15? Does the midrange of Stage 4 PI sound better?
Thanks
Kittikun
Stage Series four π and four π-18 [message #37244 is a reply to message #37243] Tue, 09 July 2002 22:24 Go to previous message
I think so, yes. The Stage Series four π is one of my favorite speakers. The four π-18 goes deeper, but the smaller four π is cleaner through the mids.
Previous Topic: 4 pi differences
Next Topic: So I lit 'em up this weekend.
Current Time: Sun Nov 22 20:57:22 CST 2026
