Home » Sponsored » Pi Speakers » 4PI or 10PI for JBL K130
4PI or 10PI for JBL K130 [message #37180] Sat, 06 July 2002 01:01 Go to next message
Solderjunky is currently offline  Solderjunky
Hi Guys, just 'discovered' PI Speakers, I cant believe what I've been missing! Does any one have experience of the JBL K130 in 4PI or 10PI designs, also do the designs need adjustment for these drive units, I'm too much of a dope to use the PI Align software! and finally could I please have the Cabinet plans for both these designs.
Thanks in advance SolderJunky
goodstuff57@hotmail.com
Re: 4PI or 10PI for JBL K130 [message #37182 is a reply to message #37180] Sat, 06 July 2002 02:12 Go to previous messageGo to next message
I've used a bunch of JBL 2205's over the years, and the K130 is somewhat similar. The 2205 is tuned a little lower and the K130 is a little more efficient. The 2205 worked very well in either a bass reflex or horn speaker, but I prefered them in seven π cornerhorns.
About cabinets, they should be tuned appropriately for the driver used. It's pretty close, so as far as size is concerned, the cabinets are interchangable. But the K130 motor cabinet should be tuned a little higher. PiAlign recommends a 2.625 cubic foot box tuned to 60Hz, using a 5.25" x 9.35" rectangular port that's 7.3" long.
If building a four π, make the box 26" x 18" x 12" and brace it well. If it's a cornerhorn, make it 33" x 17" x 9". I can send plans if you'd like, but be sure and clear out some space. Hotmail usually rejects large attachments.
Re: 4PI or 10PI for JBL K130 [message #37183 is a reply to message #37182] Sat, 06 July 2002 02:31 Go to previous messageGo to next message
Hi Wayne,
Thanks for the reply and the information, your generousity is REALLY apreciated, could you e-mail the plans to gordon.welford@ntlworld.com it should accept large files.
Thanks again. SJ
You've got mail! [message #37184 is a reply to message #37183] Sat, 06 July 2002 02:59 Go to previous message
Previous Topic: Behringer feedback destroyer
Next Topic: Instrument cabinet questions
Current Time: Fri Nov 06 07:15:11 CST 2026
