Home » Sponsored » Pi Speakers » Beta 12 isobaric sub.....
Re: should be Beta 15", sorry !! [message #37161 is a reply to message #37151] Thu, 04 July 2002 05:43 Go to previous message
Well the simplest way to do it is mount one woofer normally with the cone facing out, and simply screw another woofer on to that with their cones facing eachother. It's not the most attractive option because the basket will be sticking out, but it's by far the simplest and the best way to do it from a functional standpoint.
Adam
Previous Topic: Is there any difference between Eminence Alpha 12 and Alpha 12A?
Next Topic: double bass in stage series
Current Time: Tue Nov 17 13:20:02 CST 2026
